Good job paolo, meglio di così!!!!!
questo si che é lavoro degno di un gran club!!!
arazie mille, fabrizio
eccovi i numeri di VIN relativi al richiamo
saluti
chevyc5
QUOTE
1997-1998, 2000: Service Bulletin: Electronic Steering Column Lock May Refuse to Operate - DIC Service Message Displayed
Source: Chevrolet Dealer Service Bulletin
Number: 01-02-35-008
Subject: Electronic Steering Column Lock May Refuse to Operate - DIC Service Message Displayed (Update Column Lock Wiring, Install Revised Relay and/or Replace Electronic Column Lock)
Model Year: 1997-1998, 2000 Chevrolet Corvette Built Between the Following VIN Breakpoints:
Year
Plant
From VIN
Through VIN
1997
Bowling Green
All
1998
Bowling Green
W5100001
W5123354
2000
Bowling Green
Y5116234
End of Production
1998-2000: Recall: Electronic Column Lock
1998-2000 Corvette Recall
GM Service Operations DCS851
Urgent - Distribute Immediately
Date: September 6, 2001
Subject: 01044A - Customer Satisfaction Campaign Corvette Electronic Column Lock
Models: 1998-2000 Corvette
To: All Chevrolet Dealers
Attn: Service Managers, Parts Managers, and Warranty Administrators
This bulletin supercedes and replaces campaign bulletin 01044 issued July, 2001. The service procedures have been revised along with the schematic for all manual transmission vehicles and export only automatic transmission vehicles. The steering wheel nut part number has been added to the part information table and the part count in the claim table has been adjusted accordingly.
This campaign is in effect through July 01, 2003.
CONDITION
General Motors has decided that certain 1998-2000 Corvette model vehicles may exhibit a condition in which the electronic column lock may not function as intended. The condition could result in the failure of the steering column to unlock during initial key-in and start-up. Should the column fail to unlock, the engine will stop running if the vehicle starts to move.
CORRECTION
Dealers are to install repair kit PN 88952427 for automatic transmission Corvettes in the US & Canada or repair kit PN 88952428 for all manual transmission Corvettes in the US & Canada. For Corvettes sold in all other countries, both manual and automatic, dealers are to install repair kit PN 88952428.
VEHICLES INVOLVED
Involved are certain 1998-2000 Corvette model vehicles built within these VIN breakpoints:
YEAR - DIVISION - MODEL - PLANT - FROM - THROUGH
1998 - Chevrolet - Corvette - Bowling Green - W5123355 - W5131069
1999 - Chevrolet - Corvette - Bowling Green - X5100001 - X5133283
2000 - Chevrolet - Corvette - Bowling Green - Y5100001 - Y5116233
IMPORTANT: Dealers should confirm vehicle eligibility through GMVIS (GM Vehicle Inquiry System) or GM Access Screen (Canada only) or DCS Screen 445 (IPC only) prior to beginning campaign repairs. [Not all vehicles within the above breakpoints may be involved.]
Involved vehicles have been identified by Vehicle Identification Number. Computer listings containing the complete Vehicle Identification Number, customer name and address data have been prepared, and are being furnished to involved dealers with the campaign bulletin. The customer name and address data furnished will enable dealers to follow up with customers involved in this campaign. Any dealer not receiving a computer listing with the campaign bulletin has no involved vehicles currently assigned.
These dealer listings may contain customer names and addresses obtained from Motor Vehicle Registration Records. The use of such motor vehicle registration data for any other purpose is a violation of law in several states/provinces/countries. Accordingly, you are urged to limit the use of this listing to the follow-up necessary to complete this campaign.
MAILING INFORMATION
Dealer mailings will begin on September 6, 2001.
GMVIS INFORMATION
GMVIS information is currently available.
GM SERVICE OPERATIONS
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
© Copyright General Motors Corporation. All Rights Reserved.
SBAGLIO O LE 2002 E LE 2003 NON SONO MENZIONATE
STEFANO
Stefano
'89 convertible c4 (sold)
'98 convertible c5 (sold)
'01 convertible c5 (sold)
'03 convertible c5 (sold)
'08 zo6 c6 (sold)
Vorrei sapere da fabri di che anno è la macchina dell'amico suo che ha avuto questo problema sul C5
Vorrei sapere da chevy in che data è stato emesso il bollettino.Si legge solo che questo bollettino sostituisce quello del luglio 2001. Il fatto che si parli di auto fino al 2000 non mi convince e contrasta con tutte le notizie rintracciabili da altre parti.
Possibile che nel 2004 emettono un bollettino che sostituisce quello del 2001? Cosa ha fatto la GM dal 2001 al 2004?
Avendo io un 2003 dovrei essere contento se le cose stanno come dice il bollettino,ma ripeto,qualcosa non mi quadra
Oscar
oSCAR,
IL WARNING E' STATO EMESSO IL 6 SETTEMBRE 2001 (QUINDI PER NOI NON C'E' SPERANZA CHE CI AVVISINO) E AVEVA VALIDITA' FINO AL 1/07/2003 PER LE AUTOVETTURE MOD 1998-2000
QUELLO PRECEDENTE COINVOLGEVA LE 1997
ADESSO HO RICHIESTO AL GMLINK, FORNENDO IL VIN, DI RICEVERE AGGIORNAMENTI SUGLI ULTIMI RICHIAMI.
QUINDI PER I 97-2000 ABBIAMO I NUMERI... PER I 2000>04 ANDIAMO ALLA RICERCA.
CIAO
CHEVYC5
Blacktower
Corvette C3 Coupé 1982 White
GM Performance 350 HO Deluxe
