BUONGIORNO A TUTTI, VOLEVO CONDIVIDERE E CHIEDERE INFO SU UN'ANOMALIA CHE HO NOTATO NEGLI ULTIMI GIORNI SULLA MIA CORVETTE c5 ANNO 2002.
LA MACCHINA FUNZIONA NORMALMENTE, NEL SENSO CHE SI ACCENDE, VA SEMPRE FORTE ECC, ECC MA HO IL MINIMO TROPPO BASSO CHE SI ATTESTA SUI 500RPM GIRI AL POSTO DEI SOLITI 800 RPM, PER POI TORNARE DOPO 3-4SECONDI AI SOLITI 800RPM.
AD ESEMPIO CON LA MACCHINA IN FOLLE SE ACCELLERO A 3000 4000 RPM PER POI LASCIARE IL GAS REPENTINAMENTE, IL MINIMO SCENDE FINO A 450-500 RPM, QUASI SI SPEGNE PER POI, DOPO QUALCHE SECONDO A 500 RPM, TORNARE SU A 800RPM. ANCHE QUANDO L'ACCENDI A FREDDO DI SOLITO I GIRI SONO INTORNO AI 1000-1100RPM MENTRE ORA SONO A 800-900RPM.
IDEE? SENSORI, MAF, VALVOLA EGR? COLLETTORI ASPIRAZIONE SPORCHI? CANDELE E RELATIVI CAVI?
gRAZIE A TUTTI DELL'AIUTO
