secondo voi è vera la teoria del sabotaggio dell' L83 (guardate in giro "crossfire conspiracy")?
scusa se non me ne intendo ma piu di preciso dove dovrei guardare ???
leggete questo:
The Cross-Fire Injection conspiracy/sabotage theory
The Cross-Fire System is much ridiculed for being a weak performer. This is not entirely true since it has more Hp than all standard option engines in the previous years Corvettes. The L83 Cross-Fire Injection was the only engine available that year so it can't be compared with high performance optional engines.
The standard L48 engine had the following ratings by year:
74/195hp
75/165hp
76/180hp
77/180hp
78/185hp
79/185hp
80/190hp
81/190hp
These account for the most Corvettes produced in these years so the 205 Hp L83 Cross-Fire Injection engine has more horsepower than the most C3 Corvettes on the road.
The problem however is that the Cross-Fire Injection system has tremendous low end torque but almost no high end Hp. There is however a reaon for all this. The Cross-Fire Injection system was originally designed for the LU5 305 cid engine for the F-Body cars. GM expected that the demand for 350 cid engines would drop when emissions laws became more demanding. When the 350 cid L83 was introduced they put the Cross-Fire Injection system on it. Also the manifold has a very poor runner design. The runners are very small at the cylinder heads (almost 2/3 of what normal runners are) to increase the torque. The L98 TPI (Tuned Port Injection) engine was however also designed for a 305 cid engine. There is NO difference between the TPI manifolds on the F-Body cars and the Corvette. This is the reason why the TPI also runs out of breath on high rpm's in the 350 L98. If you've ever driven a stock L98 you may have noticed that the engine sounds like an over-full vacuum cleaner on steroids at higher rpms.
There is a sort of sabotage/conspiracy theory about the Cross-Fire manifold's runner design.
Because the L98 Tuned Port Injection engine wasn't production ready the L83 Cross-Fire Injection engine was installed as an intermediate between the "old" carbureted engines and the "new" multi point fuel injection engine, the L98 with Tuned Port Injection. Probably the initial manifold wasn't so poorly designed and had larger runners and put out tremendous torque and Hp. More than the new L98 (that has only about 25 Hp more than the "sabotaged" Cross-Fire) That couldn't go on like
that, after the oilcrisis and the constant decrease in Hp the buyers
wanted more Hp and the L98 was supposed to bring this.
A stronger performing L83 wouldn't fit in this scheme and was sabotaged to make the L98 look more glorious.
The sabotaging was done very professional. They casted the manifold so (with an indentation in in the runner bottom at the cilinder head) that a handy do-it-yourself-portmatcher couldn't open the runners up so that a strong performing system could be obtained. As lousy as the craftsmanship is in the casting of the manifold, that good is done the act of sabotaging the stuff.
There is even more circumstantial evidence for this. The CFI system is a weak performer but is a direct descendant of the cross ram system found on the highest performing chrysler/dodge production engine. The crossram layout is in fact a very good design that combines tremendous low end torque with good high end Hp and streetability.
This all is just theory but in a way it does make sense.
This all does by no means mean that the Cross-Fire Injection system is a better system than the Tuned Port Injection system. The TPI system is a more sophisticated dry induction system (meaning that the air flows dry through the intake manifold and fuel is added just before the cylinder intake ports by an injector. This means all multipoint injection systems are dry induction systems) The Cross-Fire Injection system is, like carburetion, a wet induction system. These systems have problems with fuel puddling in the manifold and this is part of the reason they have a more lopey idle. Also multipoint systems have better driveability and throttle response due to the better controllable flow of fuel to a particular cylinder.
non so tu ma io ci credo
ehhh quasi quasi .........
cmq ciao a tutti...mi chiamo flavio. questo è il mio primo intervento anche se seguo da molto il forum. l' intervento è stato d'obbligo, in quanto gia da tempo ritengo che l 83 sia sottovalutato (quanti ne ho sentiti dicendo che tale motore facesse schifo).
Ad ogni step successivo la tecnologia si migliora,ora una comparazione tra i motori l 83 e l98 lascia il tempo che trova come tra un l98 e un lt1,cospirazione contro l'l98!!!,e via di seguito...
In termini assoluti l98 e' un motore piu' moderno che segna l'inizio dell'era multipoint (avete mai pensato che gli americani non furono in grado di inventarsi ex novo una loro iniezione e andarono dai tedeschi della Bosch!!!).
Come ricordava l'articolo le due iniezioni una "umida" e l'altra "secca" presentano radicali differenze.
Personalmente cospirare contro se stessi con motori volutamente depotenziati mi sembra eccessivo in termini di analisi,in realta gia' nel suo breve passaggio dentro i cofani C4 assistiamo ad un suo incremento di potenza dai 190HP ai 205HP...
Insomma credo che quello che la storia ci ha consegnato e' una normale parabola ascendente in termini di qualita' e tecnologia sottesa da un marketing management che per sua natura tende a centellinare i miglioramenti per mantenere vivo l'interesse su un brand.
Corvette,crisi petrolifera tralasciando,e' un brand sinonimo di sportivita' che ha visto crescere progressivamente la sua potenza in termini di HP pur adeguandosi alle nuove normative in materia di emissioni e diventando anche l'11% piu' parco in termini di consumi con la generazione L98 TPI...
L83 e' a tutti gli effetti una tecnologia ibrida,un compromesso tra la vecchia alimentazione carburated e la futura multipoint,un certo ritardo tecnologico delle architetture dei motori USA e' evidente se pensiamo a un banale motore Lancia Thema 16 valvole ie dell'85 molto piu' complesso ed evoluto del L98...
Insomma credo che non ci siano state cospirazioni bensi' scelte di marketing e al massimo ritardi nell'engenering...qu esta pero' e' solo una opinione...
come al solito ogniuno dal suo punto di vista ha ragione
resta il fatto che sono comunque motori da cui si ricavano "facilmente" cavalli viste le cilindrate in gioco ma la casa non lo ha fatto ...... vuoi x motivi ecologici o restrizioni simili vuoi x i kilometraggi x cui sono previsti (ben superiori ai nostri standard) sta di fatto che forse non si e a conoscenza o non si tiene conto di scelte progettuali attuate all epoca x i piu svariati motivi
...la mia opinione combacvia quella di mic!
:D
Ragazzi sono d'accordo con voi che la sete di cavalli e' dura da estinguere ma dobbiamo anche pensare realisticamente che un mezzo di serie e relativamente di massa come la Corvette nel 1980- 81-82 era ancora da un punto di vista guidabilita' e sicurezza poco meno di feretro su quattro ruote...Da sempre gli americani hanno preceduto l'Europa in materia di sicurezza,secondo voi pur potendolo fare avrebbero potuto sbattere nel cofano di una C3 di serie 400 HP[:p][:p]...entro l'anno si sarebbero ammazzati tutti i proprietari...una cosa e' la customizzazione sportiva a posteriori o per la pista,una cosa e' un mezzo di serie che deve rispondere a determinati parametri di sicurezza credo che per quella macchina i 190 HP andassero piu' che bene, come credo che per la C4 con L98 230-240 HP siano abbastanza,insomma come ho gia' detto dobbiamo ragionare da progettisti e non da appassionati quando si giudicano le potenzialita' di un propulsore,da appassionati si sa i cavalli non bastano mai...qquello era probabilmente il giusto compromesso tra sportivita',sicurezz a,consumi-inquinamento e non ultima guidabilita'...comun que anche per me i cavalli e il torque sono sempre troppo pochi...:D:D:D:D
concordo
ti e arrivato un MP ?
Si MIc il messaggio e' arrivato ti invio il mio telefono,se sei disponibile,ci possiamo trovare ci facciamo una girata e parliamo ...di Corvette ovvio
per queste cose sono sempre disponibile ..... :D:D:D
... e io che pensavo voleste sabotare la povera Chrysler :D:D:D
